How to active DPM control panel in EWF model?
    • Anadi_Mondal
      I am trying to activate 'DPM control ' panel. According to ANSYS presentation if I turn on 'DPM collections' in the 'Model Option & Setup' tab , I should be able to activate 'DPM Control' panel. I did this ,but still my DPM Control panel is inactive. I need to set the Film step per DPM step and DPM URF. How can I do this?
      Moreover, I turn on DPM model and set two injections there.
      Anadi
      Have you set the DPM panel to "interacts with continuous phase"? You may also need transient particles.
    • DrAmine
      If not coupled to flow you will be able to see it.
    • Anadi_Mondal
      and I got my answer. I checked that if' interacts with continuous phase' is not enabled, DPM panel is active in EWF.
      Anadi
    • DrAmine
      Great!
Viewing 4 reply threads
