Discovery Import
Discovery Import
How to actvate DL?
    • anlook
       hi
      I signed up for http://account.ansys.com/ , downloaded "aimscdiscovery_190_winx64.zip" and requested 15-days trial
      Next i installed Discovery Live 19.0 from "aimscdiscovery_190_winx64.zip" (when installing I did not see anything similar to the configuration of the license)
      When I run any of the Discovery Live 19.0 sortcut I get a message that "There are no current ANSYS subscriptions that enable capability ANSYS Discovery Live", although in my account I see that I have a trial
      What is wrong? How to activate Discovery?
    • Brian Bueno
      Hello Lukash,
      Look in the folder:
      "C:Program FilesANSYS IncShared FilesLicensingwinx64"
      If there's a file there called ansysls_client.config delete it.
      • anlook
        BBueno_ANSYS
        there is no ansysls_client.config there
        the only one *.config file is C:Program FilesANSYS IncShared FilesLicensingansysli_data.config and it's empty
        I use corporate proxy, incoming connections for ansysls_client.exe and ansysli_client.exe are allowed in firewall
        Should I install ANSYS License server? As I understand trial DL uses subscription activations without using ANSYS License server
      • anlook
        when running command "ansysls_client -ShowLicenseEntitlements" i see
        INFO: C:UsersAdministratorAppDataLocal.ansys_licensing.activation
        ANSYSLI_DEVICE_USER=
        INFO: ==============================================
        INFO: Features found in trusted storage:
        INFO: Features found in trials storage:
        INFO: Features found in short-code storage:
        in C:UsersAdministratorAppDataLocal.ansys_licensing.activation folder there are five files:
        amclugnwehzwfhbnblujgjgeyygyzgbb
        amhlnyeezjnylnepgclnhsuuphhgdgfn
        ampfgpjscuwjusulflccwupdufgpzwyd
        amuebyuenjghdydjwzulwepcjclzhchn
        amzdgnwgjfupcwfghpupgdsybgcfyplg
    • Brian Bueno
      Hi Lukash,
      It sounds like there may be a few potential causes for this problem.  Registration via proxy server is not something we tested, but in theory it should work.
      The port number used during activation is 443
      You may also want to try the following if you continue having problems:
      1. Launch the Windows Command Prompt from the start menu by entering “cmd” into the search field.
      2. In the command prompt, type in:
        cd C:Program FilesANSYS IncShared FilesLicensingwinx64
      3. Once in that directory, run the following command:
        ansysls_client -DeactivateAllEntitlements
      4. Then re-run the software and activate by logging in with your Discovery account credentials.
      • anlook
        BBueno_ANSYS
        All ports (including 443) are opened for ansysls_client.exe and ansysli_client.exe
        1. Clear activation
        "C:Program FilesANSYS IncShared FilesLicensingwinx64ansysls_client" -DeactivateAllEntitlements
        SUCCESS: All active license entitlements have been returned.
        2. Run DL
        "C:Program FilesANSYS Incv190SCDMSpaceClaim.exe" /RunApollo=true /UseSubscription=true
        3. Logging my subscriptions
        4. Got error "There are no current ANSYS subscriptions that enable capability ANSYS Discovery Live"
        On My Subscriptions page I see
        Active
        for all products:
            Start date: 2018-02-01
            Expiration date: 2018-02-16
            Activation ID: Act-xxxxxxxxxxxxxxx
        In Activations tables for all devices: "Unused" and knobs RELEASE are not active
        Which files from folders:
        C:UsersAppDataLocalTemp.ansys
        C:UsersAppDataLocal.ansys_licensing.activation
         will help you identify the problem?
        P.S. You said that host for subscription licensing is "ansys-fno.flexnetoperations.com", that host can not be pinged from my computer with DL installed
        C:UsersAdministrator>ping ansys-fno.flexnetoperations.com
        Pinging sc-fnoweb.flexnetoperations.com [64.14.29.39] with 32 bytes of data:
        Request timed out.
        Request timed out.
        Request timed out.
        Request timed out.
        Ping statistics for 64.14.29.39:
            Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
      • anlook
        BBueno_ANSYS
        The problem is definitely in the proxy server!
        In the logs "licdebug.ANS365.190.out" and "licdebug.SPACECLAIM.190.out" there are records about problems with connect to the license server
        2018/02/08 17:59:10    CONNECT_ERROR        0/0/0/0   9076:ANS365:Luckas@anlook:winx64              -1069730048:192.168.127.2
                Could not connect to license server: 50090@127.0.0.1. Connection timed out while connecting to the server.
        2018/02/08 17:59:11    INFO                C:Program FilesANSYS IncShared FilesLicensingwinx64ansysls_client.exe -nodaemon -log C:UsersLUCKAS~1AppDataLocalTemp.ansysansysls_client.anlook.log
        2018/02/08 17:59:11    INFO                Started ANSYSLI server.
        2018/02/08 17:59:12    CLIENT_CONNECT        1/1/1/1   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
        2018/02/08 17:59:12    NEW_CONNECTION      Connected to local subscription handler: 50205@127.0.0.1
        2018/02/08 17:59:35    CHECKEXISTS         16014                           19.0 (2017.1128)                                     0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
                System error: 0 "".
        2018/02/08 17:59:36    SERVER_DISCONNECT        0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
                Local subscription handler 50205@127.0.0.1 has disconnected unexpectedly.
        2018/02/08 17:59:52    ACTIVATION          Act-cb1ed300-ae00-493a-8663-c272bbcb6c61                                                             0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
                Not connected to a license server for licensing actions.
        2018/02/08 17:59:56    ACTIVATION          Act-9c10b115-0ea5-4953-8176-95b55da224d0                                                             0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
        2018/02/08 17:59:57    ACTIVATION          Act-830de992-a712-45cf-8b74-914ba39e203c                                                             0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
        2018/02/08 17:59:57    ACTIVATION          Act-60b7ae07-4a24-428b-a38b-ae130eb6c737                                                             0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
        2018/02/08 17:59:58    ACTIVATION          Act-5c5b5ed3-3586-4826-90b3-9a00df069d8b                                                             0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
        2018/02/08 17:59:58    ACTIVATION          Act-359c41a0-8425-4942-a1fb-6b8c4d3ec885                                                             0/0/0/0   9076:ANS365:Luckas@anlook:winx64              11644:192.168.127.2
        2018/02/08 18:00:19    CONNECT_ERROR        0/0/0/0   9076:SPACECLAIM:Luckas@anlook:winx64          0:192.168.127.2
                Could not connect to license server: 50205@127.0.0.1. Connection timed out while connecting to the server.
        2018/02/08 18:00:20    INFO                C:Program FilesANSYS IncShared FilesLicensingwinx64ansysls_client.exe -nodaemon -log C:UsersLUCKAS~1AppDataLocalTemp.ansysansysls_client.anlook.log
        2018/02/08 18:00:20    INFO                Started ANSYSLI server.
        2018/02/08 18:00:21    CLIENT_CONNECT        1/1/1/1   9076:SPACECLAIM:Luckas@anlook:winx64          11636:192.168.127.2
        2018/02/08 18:00:21    NEW_CONNECTION      Connected to local subscription handler: 50247@127.0.0.1
        2018/02/08 18:00:43    CHECKOUT            16014                           19.0 (2017.1128)             1/0/0/0                 0/0/0/0   9076:SPACECLAIM:Luckas@anlook:winx64          11636:192.168.127.2
                System error: 0 "".
        2018/02/08 18:00:44    SERVER_DISCONNECT        0/0/0/0   9076:SPACECLAIM:Luckas@anlook:winx64          11636:192.168.127.2
                Local subscription handler 50247@127.0.0.1 has disconnected unexpectedly.
        I installed DL on a computer with direct Internet access (no proxy server) and the activation went without problems
        But the GPU on that computer does not meet the requirements of DL, so the issue of the activation of DL on the computer with the proxy remains open
        Due to the fact that the developers have not tested the activation via proxy, I have already spent half of the trial period without running the program
        What is the point of giving trial if there is no way to use it?
    • Brian Bueno
      Hi Lukash,
      We are working to resolve this issue.  In this case, it seems the process required to activate the software is being stopped before attempting to connect to our server.
      Can you tell me if there are any major differences between the 2 PCs you tried this on?  Did the PC with a free internet connection have the same security settings as the other one as far as antivirus or anything of that nature?
    • anlook
      BBueno_ANSYS
      Both computers Win 7 SP1 Pro (with proxy and without proxy) have the same configuration, security and antivirus settings.. Moreover disabling antivirus and Windows firewall on computer with proxy does not help
    • fugen.li
      Hello, lukash I just see you troubles, I just solved this by follow the steps of the install files. I believe you that you do not start you trails start trails now, then you will solved it
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Viewing 5 reply threads
