March 27, 2022 at 9:27 am
mxy200036
SubscriberHello, I want to use CHARGE and MODE for co-simulation.
I would like to ask is it possible to add insulator materials with anisotropic dielectric constant in CHARGE? how should I do it?
Grateful!
March 30, 2022 at 5:33 pmKhashayar Ghaffari
Ansys EmployeeHi Thanks for your question. Unfortunately it is not currently possible to define anisotropic dielectric properties in CHARGE.
Best regards
- Error on Lumerical device
2630
2104
1327
1110
461
