March 14, 2021 at 9:35 am
AhmadMwaheb
SubscriberHello,nI'm using ANSYS FLUENT. I need to make an inlet with flow rate of 5 CFM and static pressure of 50 Pa. What is the best way to do that?. -
March 15, 2021 at 4:36 am
Keyur Kanade
Ansys EmployeeYou can not define mass flow rate and pressure at inlet. This would be over constrained problem. nUse pressure inlet and pressure outlet with target mass flow rate. Once it is converged use that mass flow rate at the inlet. This is somewhat iterative procedure. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
2706
2146
1357
1144
462
