June 16, 2020 at 10:10 am
June 16, 2020 at 11:11 am
SubscriberANSYS provides few materials with S-N data. Mostly, you have to provide your own data. Do you have the S-N data for AA7075-T651? Once you have that data, which is simply two columns: Cycles and Alternating Stress, open Engineering Data, drag and drop from the Life category the S-N Curve item onto your material, then paste the Cycles and Alternating Stress data into the blank table.
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5364
3363
2471
1310
1018
