February 13, 2021 at 3:11 am
knik123
SubscriberHi,nI have a space truss built from multiple 2D lines in the spaceclaim geometry and I want to prepare them all to have a solid circular beam cross-section but once I do that I can not individually adjust the cross-sectional areas of the prepared beam elements. If I try to adjust one, they are all adjusted. How can I adjust it so all the circular beam elements have a mixture of different cross sectional areas? n -
February 13, 2021 at 1:28 pm
SubscribernAssign an individual cross-section name to each beam. Don't use the same cross-section name for every beam.nEven if you want them to all start as a circular cross-section with a diameter of 5 mm, name them like this:nBeam A 5 mm circlenBeam B 5 mm circlenBeam C 5 mm circlenetc.n -
February 13, 2021 at 5:01 pm
knik123
SubscriberThank youn
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5242
3297
2467
