February 5, 2021 at 12:18 pm
Kim
Subscribern -
February 6, 2021 at 1:17 pm
SubscribernChange the dimensions of the beam in a geometry editor and update the mesh to the new shape.n -
February 12, 2021 at 9:30 am
Kim
SubscribernThank you for you answer! Do you know if there is any other way besides changing the geometry? nOr maybe even how the flexural rigidity could change throughout the processing (such that the flexural rigidity becomes less the more it is bent). nBest regards, nKim n -
February 12, 2021 at 10:59 pm
SubscribernInstead of changing geometry, you can change the material property Young's Modulus. That changes the flexural stiffness of the part during the elastic portion of the deformation.nReduce the Yield Strength in the Kinematic Hardening Plasticity Material Model to reduce the stiffness the more the part is bent.n
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5360
3345
2471
1310
1018
