October 6, 2018 at 1:29 pm
fa-ri
SubscriberHello all,
I'm working with ANSYS 18.2 version,
I'm doing a 3d simulation of flow field for a 4-rotor UAV.
I have a transient state case.
The steps I did:
1.used (realizable.k-e.scalable wall fn)
2.turn on mesh motion for each blade
3.used 2 pressure outlet
4.time step size :0.01
The lift values obtained for each rotor are small and negative and The flow lines are not symmetric
please help me:
1. How do I know that my simulation is correct?
2. How to calculate the total lift and thrust values
Thank you
With regards
fa-ri
October 8, 2018 at 5:36 am
seeta gunti
Ansys EmployeeHello Fari,
Regarding calculation of lift and drag, we have a tutorial in the youtube. Please watch the video as given below.
Make sure that you gave the correct input values for rotor axis direction, axis center and rotational speed ( RPM/ RPS).
Seeta
October 8, 2018 at 7:46 am
fa-ri
SubscriberHello Seeta
Thank you for your response.
here is my data
Forces - Direction Vector (0 1 0)
Forces (n) Coefficients
Zone Pressure Viscous Total Pressure Viscous Total
prop_1 0.017310849 -9.460496e-05 0.017216244 0.028262611 -0.00015445708 0.028108154
Net 0.017310849 -9.460496e-05 0.017216244 0.028262611 -0.00015445708 0.028108154
But the result is not correct by comparing values with experimental values.
and about the steamlinesThere is a lot of Wake streams.
how can i khow that my simulation is correct?
October 8, 2018 at 10:45 am
seeta gunti
Please make sure that you give the right boundary conditions and right axis rotation and center of axis of the rotor. Sometimes, the speed will be given wrong. Please check you use the right units.
Refer some tutorials on mesh motion with some rotational speed in Youtube to check your settings.
October 8, 2018 at 10:53 am
Karthik R
AdministratorHello,
Just to add to Seeta's comments, if you are seeing discrepancies only in the coefficients (and your forces seem correct), you might want to take a look at your reference values).
Thank you.
Best Regards,
Karthik
October 8, 2018 at 12:10 pm
fa-ri
SubscriberHello Karthik,
I've checked the values (both) and the amount is too much lower than reality
With regards
fa-ri
2616
2098
1323
1108
461
