August 7, 2019 at 11:37 am
ZacP
SubscriberHi,
I am modelling a bridge pier subjected to lateral debris flow loading. The pier structure is 10m tall but I only want to apply a pressure 7m of the height (flow height = 7m) to the left curved face. Is there a way this is possible to do?
Thanks
August 7, 2019 at 12:57 pm
jj77
SubscriberGo to loads and pressure - if you do not have a face there then you need to split the larger face into two (@ 7 m) so you can get the face you need to apply the load on.
Split:
August 7, 2019 at 1:04 pm
ZacP
SubscriberHow can I split the larger face into two? I made the model on solid works and then uploaded to ANSYS, should I split the face in two in solid works and re up load?
August 7, 2019 at 1:06 pm
jj77
SubscriberEither you split it there or you do it in DM - see tutorial above for that.
August 7, 2019 at 2:27 pm
ZacP
SubscriberI applied a split line to the model on solidworks and then reuploaded to ANSYS. It now comes up with the error that I've exceeded the product license limits when I try to solve, any ideas why?
August 7, 2019 at 2:30 pm
jj77
SubscriberThe message is clear - you have to many elements. You need a coarser mesh. PLease close the original discussion and start a new one when you had a separate issue
2078
1289
1106
459
