November 10, 2023 at 1:50 am
kartikeya parmar
Subscriberi have a rectangular channel with water as inlet on the top wall i want to apply a dye like fluid and see how dye mixes with fluid as it passes but i am not getting how to apply dye concentration on the wall can anyone please help. Just like we apply temperature on a wall can we similarly apply concentration also on a wall please suggest
November 14, 2023 at 3:51 pm
Forum ModeratorIt's not quite that easy at the moment. If you turn on species there's a specified value (from memory) but it's often that we'd use a source term into the near wall cell. There's an enhancement request in for the feature, but I have no knowledge as to when it'll happen.
November 14, 2023 at 4:15 pm
Ahmed Hussien
Ansys EmployeeYou can refer to Section “7.4.15.6 Species Boundary Conditions for Walls” in the Ansys User Guide for more infromation.
https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/flu_ug/flu_ug_bcs_sec_bound_cond.html#flu_ug_sec_changes_wallspecies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
