How to apply fluid penetration pressure in this case
    • rainbowdonkey
      I can't always choose the side exposed in that direction
      how to select that part?
      Thanks!
    • peteroznewman
      It looks like you have a 2D model. In SpaceClaim, create two radial lines on the circle at angles that intersects the circle at the two points where you want to break the edge to apply a pressure load to that segment.
      • rainbowdonkey
        thank you! but if i apply pressure on a specific segment , i still cannot choose the segment exposed in that direction after starting to solve this model
    • dinhan0394
      You can define a Fluid Pressure Penetration through Contact elements.
      Reference Ansys Help Technical Showcase: Chapter 3: Fluid-Pressure-Penetration Analysis of a Sealing System
      or workshop WS5a-Fluid Pressure.pptx in Nonlinear Connection lecture.
