How to apply load for a particular length of an edge
    • tahm
      I want to know application of various types of loads and displacements in ANSYS workbench.
      Suppose I want to apply displacement load condition for say 6m for an edge of 20m length.
    • peteroznewman
      In CAD, split the 20 m long edge to make a 6 m long section where you want it.
    • tahm
      What is the right way to do this problem?
    • tahm
      In this model footing width 6m and depth and height of soil 20m.
      Only soil is used for modeling and properties are  E=10000kPa and poisson's ratio 0.4
      Could you please give a demo on this?
      It is a 2D plane strain analysis
    • peteroznewman
      Use a Plane Strain model.
      In Workbench, drag out a Static Structural analysis.
      Double click on Geometry to open SpaceClaim.
      In SpaceClaim, File > SpaceClaim Options > Units > change the units from mm to m.
      Click on the Sketch button and select the XY plane.
      Click on the Rectangle tool and sketch a rectangle, you can type 20 in each box.
      Click on the 3D mode button, the rectangle will become a surface.
      Select the surface and click on the Sketch tool.
      Click on the Rectangle tool and draw another rectangle from the top left corner. Make this rectangle 6 m wide and 6 m deep. That will split the surface into two faces and you will have your 6 m edge.
      Close SpaceClaim.
      Follow these directions (not step 1 in your case, and step 2 applies to Static Structural in your case).
    • tahm
      Thank You Peter!
Viewing 5 reply threads
