Tagged: 2-way-fsi, acoustics, mechanical-apdl, transient-structural
March 9, 2021 at 11:00 pm
dardhruv
SubscriberHello All,nI am planning to perform a Transient Analysis on CMUT (Capacitive Micromachined Ultrasonic Transducer) Membrane.nFor that, I have two case ncase 1: na 20-ns-long 70-V pulse is applied to the without dc biasnnCase 2:nthe device is driven by a 50-V, 5-MHz, 1-cycle tone burst with no dc bias.nnI have to use Trans126 element so I have to EMTGEN command but I don't know How to interpret this two different case and How can I apply?nI am using Ansys workbench but for this loading, I am using Command snippet (APDL)nnCould anyone please help me to apply this loading condition?nI have a fluid medium on top of that so my aim is to find out Pressure after applying this loading conditioThanks and Regards,nDhruvi -
March 11, 2021 at 2:47 pm
dardhruv
SubscribernnCould you please help me in this or is it possible to recommend anyone who can help me in this?.Thanks and Regards,nDhruvinn -
March 11, 2021 at 3:22 pm
Erik Kostson
Ansys EmployeeNever used this element but from the example in the apdl manualnnYou can use the D,NODENR,VOLT,%VOLTTABLE%nTo assign a volt table called %VOLTTABLE%nnSee this example in the apdl coupled physics chapter 2 for more info on this element:n2.9.8. Example: Electromechanical AnalysisnnThis is a good resource also for time tables - also the help manual has relevant info:nnThank you and I hope this helps because as I said I have not used this elementnnErikn
Trending discussions
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
