How to apply uniform temperature change in coupled thermal-structural analysis in ANSYS APDL
    • Nuno koh
      I'm using ANSYS APDL.
      I want to do analysis about a time varying temperature loading thermal-mechanical analysis.
      Generally,  coupled thermal-structural analysis is used for it.
      Firstly, thermal analysis is completed and then, followed by structural analysis.
      I have interested in thermal analysis as below.
      1. A PCB strip is pre-heated in 220'C bake.
      2. The PCB is cooled down to 25'C
      3. The PCB is re-heated to 260'C
      But, I want to use nodal temperature not heat flux as loading, in the menu path  'solution>Define load> apply>temperature' load temperature.
      and I want that temperature distribution is even because it is steady state, (just it is different by time not location).
      How can I make the solution.
Viewing 0 reply threads
