March 18, 2021 at 9:21 am
Lukas8778
SubscriberHey there,
I need to design and simulate a PMSM for a master thesis. I'm new to the software and wondering how it is possible to assign a constant sinusoidal current to my 3 phase machine via Maxwell2D.
I created an IPM Synchrounous machine via RMxprt, when I create a Solution setup I only have the option to define the rated voltage as follows:
March 18, 2021 at 2:06 pmNavya C
First, create a full maxwell model from the RMXprt model as discussed in your other post.
Then under the project manager window for the maxwell design change the excitations for the phases to current and give a required sinusoidal equation for each phase.
For additional help please refer to the Maxwell help document.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
