TAGGED: 3d, ansys-spaceclaim, cad, mechanical, spaceclaim
February 15, 2022 at 3:46 pm
Karthi111
SubscriberFebruary 21, 2022 at 5:42 pmNaresh Patre
I am not sure if I understood your question correctly, but if you loop over each face, you can access its mid point and then specify it in the datum point creator command.
- Naresh Patre
February 22, 2022 at 3:25 pmKarthi111
Thank you for answering to my question. I want to create a series of points all over the surface. Like 50 point distributed on a single surface. I thought of doing this using a loop and varying the parameters inside the DatumPointCreator() object. I can see that by changing the 2 numerical values inside the DatumPointCreator.Create(), I can create different points on the surface. But, I cannot find a pattern it varies. Can u please explain what the two numerical values denote?
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3812
2589
1849
1244
600
