February 28, 2022 at 7:00 am
Susan
SubscriberDear All,
I am doing opimtization and want to read result files (e.g. collection efficiency) generated in fensap-ice work directory each step, but I don't know which result file contains that information. When I open the droplet file in the work directory after DORPLET computation, it shows messy codes.
Also, which file has and how can II read required heat loads when I choose Compute IPS conditions?
Could anyone help, please? Thank you very much!
Best regards,
Susan
March 10, 2022 at 9:52 amShoaib Shah
Ansys EmployeeHi Susan
Drop3d will save a 'droplet' solution file as shown in your screen shot. This is where you will details of the droplet fields including collection efficiency (beta). Make sure to import reference conditions for inlets to ensure you have a converged solution.
For the ice3d run, when you run it, it will save a swimsol file. this will contain the icing solution with all its field.
I strongly recommend you to look at the manual and tutorial guide before trying out FENSAP-ICE.
Thank you
March 11, 2022 at 8:35 amSusan
SubscriberThank you very much. However, how can I read droplet file externally and extract the collection efficiency information?
2656
2120
1349
1118
461
