Discovery Import
Discovery Import
How to automatically terminate an ANSYS run as soon as a certain value is reached?
    • FordPrefect
      Hello everybody,
      I am looking for a way to terminate an analysis run automatically as soon as a certain check value has been reached. When using the arc-length method there is the command ARCTRM. The command may be used to detect the limit load; or it terminates the analysis as soon as a defined DoF reaches a defined value. However, I would like to terminate the analysis automatically as soon as there is more than, let's say, 5% plastic strain in a certain region of the model. A workaround when not using arc-length could be a restart-cascade: stopping after each substep, checking the data, and restart again. This could be done in APDL but it is tedious, and slow. Also, the arc-length method does not support the restart capabilities of ANSYS.
      Is there a way to script a user subroutine for the solver for this task? I fancy something like the result tracker tool but not limited to a single node and with additional abort criterion. I have to admit that I am not overly familiar with any other programming language than APDL and a little bit of Python.
      Thanks for your support!
      Kind Regards
      Andreas Panenka
    • Naresh Patre
      Hello Herr P.
      Regarding your question on ANSYS Mechanical and APDL, please post it on ANSYS Student Community or ANSYS Customer Portal based on the type of license that you have. This forum is specifically intended for seeking assistance on ANSYS Discovery products. Thank you for your understanding!
