March 8, 2021 at 10:19 pm
xin.yang
SubscriberHi,
Could anyone give some advice how to split the block for the geometry as follows:
1, it is a bend pipe inside a box
2, geometry is not complicated, but the strategy to build the block looks like complicated.
3, Could anyone give some advice?
Many thanks.
pmxy
March 9, 2021 at 3:37 amKeyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please upload images using upload image functionality. nAre you using SpaceClaim meshing? What kind of mesh you are looking for? nThis looks like fluid domain. For this tet + prism you should be good enough with min orthogonal quality more than 0.1. nIf you need full hex then you may need to do considerable splitting. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 9, 2021 at 7:39 amxin.yang
SubscriberAs ANSYS Staff, we can not download attachments. Please upload images using upload image functionality. Are you using SpaceClaim meshing? What kind of mesh you are looking for? This looks like fluid domain. For this tet + prism you should be good enough with min orthogonal quality more than 0.1. If you need full hex then you may need to do considerable splitting. Please go through help manual for more details Regards,KeyurHow to access Ansys Online Help DocumentHow to show full resolution imageGuidelines on the Student CommunityHow to use Google to search within Ansys Student Communityhttps://forum.ansys.com/discussion/comment/109936#Comment_109936
The attached file is the orginal icem .tin file. You can ignore it.nI am using ICEM CFD to generate structured mesh.nnViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2064
1279
1096
456
