January 10, 2023 at 4:51 pm
Loic Feukam Takoundjou
SubscriberI want to calculate the losses of a curved waveguide.
After defining the source, I have defined the monitors to give the transmission coefficient at different sections of the curved structure.
The power I get from the monitor placed at the end of the bend is negative and is of the order of e-41 and also has an imaginary part (see screenshot).
Is this a programming error?
How can I deduce the losses from the complex powers I get at the end?Thank you in advance.
January 11, 2023 at 6:57 pm
Guilin Sun
Ansys EmployeeSomehow my reply was not posted yesterday.
There are a few things:
1: negative power means the power flow is toward the negative axis.
2: the data you viewed is the raw power data without normalization.
3: Power is usually normalized to sourcepower transmission - Script command
4:For such bend waveguide, it is better to use FDE in MODE to get the loss contant:
Solving bent waveguides in FDE and FEEM
5: you can also use the mode source to get the bending loss: choose "user select" and calculate the mode
Choose PML boundary conditions:
set the bending radius:
specify the wavelength or frequency, then "calculate modes":
Please try.
For the half circule bending, we do not recommend to simulate it using FDTD. If you really want, please use mode expansion monitor, or better port to get the modal S paramter.
Please write a new post if you have other questions.
January 17, 2023 at 9:19 am
SubscriberThank you for the informations, I have followed your instructions for calculating losses
- Error on Lumerical device
2666
2120
1349
1132
461
