November 16, 2020 at 4:45 pm
manelaero2020
SubscriberHello every one
Have you an idea please how to calculate cyclonic filter efficiency in Ansys Fluent ?
( More precisely how to deduce this from results obtained after simulation?
For exemple : Look at the following video
Thanks you
Kind regards
November 16, 2020 at 4:58 pmRob
Forum ModeratorFrom the video no idea. From the TUI reporting, easy. nNovember 16, 2020 at 6:40 pmmanelaero2020
SubscriberWhat do you mean please by TUI reporting ? nNovember 16, 2020 at 6:58 pmmanelaero2020
SubscriberThanks you very much ; no problem nFinally i have found the solution nnnI share this important imformation with all whose are reading my comment !The solution is the following video (32:35) : nGood luckViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
8740
4658
3151
1678
1452
