How to calculate Life cycle for any Given Material?
    • Aakashsingh9896
      how to Calculate life of a design body by giving a different material out of the study material and how to find safety factor for the same materials? n
    • Daniel Shaw
      By life, do you mean the fatigue life? If so, you can use the Mechanical Fatigue Tool to calculate the life and safety factor.. n
    • Aakashsingh9896
      actually I need to find life for given components from different materials which is not in the library so put all the static input but for find life , damage and factor of safety we need SN curves so is there any formal aur theory to find this out?n
    • Daniel Shaw
      If you want to use SN to determine the fatigue life, you need S-N curves. If you do not have any fatigue test data, there are methods to estimate the S-N curve using material other material properties, but it is not precise. You can obtain S-N curves for many materials from commercial sources.
Viewing 3 reply threads
