How to calculate material removal rate using single phase fluid flow in ANSYS FLUENT?
    • NiteshDubey
      I am new to the fluid mechanics community. I am using single-phase (Non-Newtonian fluid ) for my simulation. I want to determine material removal rate. How can I do it? Any model ar test file by which I can do it for single phase.
      Any help will be highly appreciated.
      With regards
      Nitesh
    • DrAmine
      Material removal at what? Do you mean mass flow of the fluid escaping the domain? Or really the rate of material (of your housing for example) being removed?
    • NiteshDubey
      Material removal at the wall (workpiece). Yes, mass of fluid moving past against the workpiece and escaping from the outlet.
      Example: similar to erosion caused by particles in the pipeline.
    • Keyur Kanade
      for single phase flow you can have mass flow rate at outlet. it is at results-surface integrals-mass flow rate.
      if you want to material removal like erosion, i think you may need multiphase model.
      Keyur
Viewing 3 reply threads
