Tagged: angles, diffraction, gratings-farfield, Lumerical-FDTD
March 22, 2022 at 7:05 pm
fdtdisgreat
SubscriberHi,
How do I calculate phi and theta from the results of gratingu1 and gratingu2? My guess would have been phi = arctan( u2/u1) and theta = arcsin( sqrt(u1^2 + u2^2) ), but for some of my results sqrt(u1^2 + u2^2) is greater than 1, so this cannot be true (where u1 and u2 are the results of gratingu1 and gratingu2 respectively for the same beam). I checked the online documentation of gratingu1 and gratingu2 and I couldn't see any information on this. Thank you in advance. (Note: I'm defining theta and phi as is conventionally done in spherical coordinates)
March 29, 2022 at 10:11 pmTaylor Robertson
You are on the right track, and for more information on the coordinates I would refer to the following references.
This page should explicitly state the coordinate transformation
https://support.lumerical.com/hc/en-us/articles/360034394294
The following is a script command that should perform the transformation for you
https://support.lumerical.com/hc/en-us/articles/360034410194-farfieldspherical-Script-command
- Error on Lumerical device
2630
2104
1327
1110
461
