July 3, 2019 at 1:36 pm
Tayyaba
SubscriberHi
I am working with the CFD of a 3D flap . I need to have distribution of pressure forces on a section of a flap. What I get from Fluent is only the pressure distribution in Pascals not the pressure force in Newtons.Do I have to integrate this pressure over the area of flap so get force?
Moreover from Reports-Forces, I get the net value of drag force(including pressure and viscous forces) on the whole flap. It is not showing that how drag force is distributed along the different position on the flap for example across the height or length of the flap.
Flap is attached and forces are needed across the highlighted
edge .
Waiting for your kind response.
Regards
Tayyaba
July 3, 2019 at 2:24 pm
Ansys EmployeeThe Force Report is per surface, if you need a finer resolution separate the faces and report on them individually.
July 3, 2019 at 2:48 pm
Tayyaba
SubscriberThank you very much for your kind reply, but how to separate different faces after solution?
Regards
Tayyaba
July 3, 2019 at 4:05 pm
Ansys EmployeeLook on the ribbon under Domain, Separate faces. It'll potentially mess up the Workbench workflow so make sure you save a copy of the project before doing it.
July 4, 2019 at 12:49 pm
Tayyaba
But again it gives the net value and what I need is the force at different locations across the flap or you can say force distribution as pressure distribution in Fluent
And also my question is: the net value of force is exactly at which location on the flap?
Regards
Tayyaba
July 4, 2019 at 1:17 pm
Ansys EmployeeIt's for the surface you report on. If you need to break it down you can create many surfaces and report those.
3694
2564
1765
1234
592
