How to calculate reaction enthalpy source in fluent?
    • Weiqiang Liu
      Hi all,
      I have a question about how to calculate reaction enthalpy source in fluent. The reaction is:
      C+O2->CO2
      standard enthalpy of formation of carbon and oxygen is 0. specific heat of carbon is a constant. specific heat of oxygen and carbon dioxide is a piece wise polynomial fit of temperature. enthalpy of formation under any temperature is expressed as:
      H(T)=H(0)+∫ Cp*dT
      Because specific heat of oxygen and carbon dioxide is a piece wise polynomial fit of temperature. Therefore, enthalpy of formation is also a piece wise polynomial fit of temperature.
      Then formation enthalpy of product minus formation enthalpy of reactants gives reaction enthalpy. Reaction enthalpy is also a piece wise temperature dependent function.
      Am I doing right?
      Best
      Weiqiang
    • DrAmine
      The enthalpy of reaction calculated by Fluent is based on formation enthalpies. Check Energy Sources Due to Reaction in Theory Guide.
      I guess it is correct what you are writing. But I do not comment on user defined approaches.
    • Weiqiang Liu
      Hi Amine,
      Are there some macros with which I can obtain enthalpy of formation of species under any state? Or I must calculate enthalpy of formation by integration of specific heat multiplied by temperature?
      Best
      Weiqiang
    • DrAmine
      Not aware about that. Please have a look into the way defined the formation enthalpy and heat of reaction. You see thst no integration is done.
    • Weiqiang Liu
      ok , thanks very much!
Viewing 4 reply threads
