May 25, 2022 at 10:01 pm
iris
SubscriberHello, could someone help me, I am a beginner and I am making a design of a coil as shown in the figure.
I simulate the electric field and that gives me some values but when simulating the SAR, it tells me that
the average SAR calculation with invalid tissues, please check your settings
However, the density is 1g/mL and it is the one that is placed in the configuration.
What would be the way to calculate the Sar of this coil?
I would appreciate your help on the matter.
May 26, 2022 at 5:07 pm
Navya C
Please confirm what Ansys tool and which version are you using?
Regards Navya
May 27, 2022 at 2:19 am
May 31, 2022 at 5:28 pm
Praneeth
Please go through "Modifying SAR Settings" section of the HFSS help document for detailed information.
Kindly note that precise guidance is more involved process which cannot be provided in this forum because of its open nature.
If you have access, please raise service ticket so that we can assist you even better.
All the very best Praneeth.
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1865
1272
610
