May 3, 2023 at 2:03 pm
Assala Trabelsi
SubscriberHello every one ,
In fact I'm crating a new material(PBT_GF30 : Reinforced short fiber material ) in Material Designer and to do that I need to put the plastic strain Vs stresses . I used the known formula to do this conversion https://docs.google.com/spreadsheets/d/1ZKJdmswIPB-7Rw3j6I_6ganKS_MfIs5X/edit#gid=392220995
I was surprised to get this 2 curves because I suppose that the first point for the plastic strain=0 must be equal to the yiled stress . The formula used are shown below
Thank you for your response
May 4, 2023 at 12:01 pm
Ashish Khemka
Ansys EmployeeHi,
Please see if the following course helps you:
Defining a Multilinear Hardening Plasticity Model | Ansys Courses
Ashish Khemka
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5290
3311
2471
