October 31, 2018 at 5:28 am
abhay mahar
Subscriberhow to calculate time step in transient modal analysis ?
October 31, 2018 at 5:40 am
Keyur Kanade
Ansys EmployeeUsually time step < (min mesh size / velocity)
Please check courant no. and then decide time step size.
October 31, 2018 at 5:53 am
abhay mahar
Subscriberi have excel data in form of time .time from .002 to 1.5 sec, with interval of .02 sec. how can i find velocity ? it is modal analysis with transient
October 31, 2018 at 12:10 pm
SubscriberThis is a Transient Structural model, right?
What is the highest frequency you want to include in your Transient simulation? How many Modes did you request in the Modal analysis and what was the frequency of the highest mode?
You say your Excel data has an interval of 0.02 seconds. Is that a typo? That is a sampling frequency of 50 Hz which is very low. Since your first time is 0.002 s, I think that is the interval, which means a 500 Hz sampling frequency. It is recommended to have 20 points per cycle of vibration in your time-history. That means you could simulate frequencies up to 25 Hz.
What quantity is the Excel data? I assume it is acceleration, but maybe it's displacement. Where was this Excel data measured? How many axes were measured? If only one axis, what direction was measured? What are the boundary conditions for the Modal analysis?
If the accelerometer was on the ground, you can apply that acceleration to the model and solve. Once solved, Velocity is one of the results you can plot.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
