September 6, 2022 at 2:59 pm
phuonganhlovely.me
SubscriberHello evreyone
i using below formula to calculate the THD.
the plot i get from perform FFF in EDT
can you tell me that my calculation is correct ?
every collum i draw v1, v2, v3 ...in the fig is harmonic order. (i am not sure) can you help me explain ?
if i want to display 10 harmonic order i need to total 10 value continously (ex: 1,2,3,4,5,6...)or just choice the harmonic that i want for example (1,3,5,7,10..) and then calculate it
thank you very much.
September 7, 2022 at 12:32 pm
Howard
Ansys EmployeeHello phuonganhlovely.me,
We would use above equation to calculate THD with v1, v2, v3, v4,...,vn .
HDLI
September 9, 2022 at 9:27 am
phuonganhlovely.me
SubscriberHi HDLI
thank you for your reply.
how can i get the value of V1,V2,V3.....?
and how many harmonic can i get from plots? also how to choice the hamornic to perform FFT graph?
i a newbeis so im not clearly sorry for this inconvenient
best regard.
- Maxwell, HFSS or Q3D?
- Error
2720
2146
1357
1150
462
