August 12, 2019 at 4:17 pm
August 13, 2019 at 5:08 am
DrAmine
Ansys EmployeeYou already have access to it at walls. What is still missing? -
August 13, 2019 at 12:16 pm
Sam001
SubscriberAmine,
Am I to use the net for the overall Wall Temp?
Thanks,
Sam
August 13, 2019 at 2:31 pm
Ansys EmployeeDepends which wall you want to the data for. You need to work out what you want data for.
August 13, 2019 at 5:48 pm
Sam001
Subscriberrwoolhou,
ok, what of fin area/Total area?
August 14, 2019 at 4:42 am
DrAmine
Ansys EmployeeMore details: what do you want to Do? -
August 21, 2019 at 12:42 pm
Sam001
SubscriberAmine,
finding Stanton number?
Sam
August 21, 2019 at 12:53 pm
DrAmine
Ansys EmployeeSo you need averaged values along the wall (say like area-weighted) and the whole area of the wall. Stanton is: St = Nu / (Re * Pr) so you need to use some "global" charateristics for your flow. Fluent provides Surface Stanton Number as post-processing variable based on the reference values.
August 21, 2019 at 12:59 pm
Sam001
SubscriberAmine,
Please, can you break down the term "global" characteristics?
Sam
August 21, 2019 at 1:12 pm
DrAmine
Ansys EmployeeReference Temperature, Reference Length for example to define Nu and Re.
August 22, 2019 at 3:05 am
pssjn
Subscriberis it possible to calculate the wall temperature of 'zero thickness wall'? what is the best way to calculate natural air ventilation rate of a room in fluent?
Best regards,
Farhan
August 22, 2019 at 5:16 am
DrAmine
Ansys EmployeeYes you can. Please mark this as is Solved and open new discussion for your new question.
2656
2120
1347
1118
461
