how to carry out harmonic analysis to free piezoelectric PWAS in workbench ?
    • Md_Salem
      I used to do harmonic analysis to free PZT PWAS in APDL in order to get electromechanical impedance spectrum VS frequency , as next sequence:
      1- define the element and piezo-material structural parameters , coupled parameters and electric permittivity
      2- modeling and meshing the free PWAS
      3-select the upper surface nodes
      4- create component for the top surface:
      CM,TOP,NODE
      5- couple the VOLT DOF for the top surface as set '1'
      CP,1,VOLT,ALL
      6- get node 'N1' on the upper electrode:
      *GET,N1,NODE,,NUM,MIN
      7- do the same for the lower surface ( BOTTOM,2,N2)
      8- apply VOLT loads on the upper and lower surfaces :
      D,TOP,VOLT,1
      D,BOTTOM,VOLT,0
      9- define the frequency range (start - end) and so frequency steps
      10 - do the analysis
      11- extract the charge on electrode and do external math to convert it to current then impedance and get the spectrum .
      the output is 100% experimentally verified.
      my question is how to carry out this procedure down from step number 4 for free PWAS ? , and if it is possible to get the impedance calculated directly in workbench 21R2 ?
    • Ashish Khemka
      Please see if the following helps:
      ANSYS Tutorial for PWAS (sc.edu)
      Regards Ashish Khemka
    • Md_Salem
      appreciated for your help, but unfortunately the attached video shows the steps that I have already stated for simulation of PZT in APDL. I need to learn how to do it in ANSYS 21R2 WORKBENCH
      Regards MD Salem
