3D Design
3D Design
How to chang unit in Ansys Discovery 2023?
    • DmArcher
      I was trying File Memu -> Settings -> Units and Display Precision. And then change the length.
      The default is in mm and I want to set the unit to m.
      There is no OK button so I assume that it is auto-saved.
      However, when I start to sketch my shape, I realized that the unit is still mm.
      Could anyone help me?
    • Saurabh Patil
      Hi @DmArcher
      Changing units from the File Settings menu is applicable for ‘All New Documents”. You can change the in document units  from the bottom left quick measurement tab (click on the bottom left box with coordinates to let the window pop)
      Regards
      Saurabh
