March 11, 2021 at 4:00 pm
maurya
SubscriberHello sir
How we can change the way of erosion of elements from strain to stress?
March 13, 2021 at 12:20 pmramgopisetti
Subscriberfrom the On Geometric strain limit set to No it will give the option on material definition and you need to specify failure criteria in the material model, like failure strain or stressncomment down your responsenCheers, nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2616
2092
1321
1108
459
