How to change material in Ansys Discovery
    • amansrivastav715
      Hello everyone,
      I am using Ansys Discovery 2022 r2, can anyone please tell me how to change material in that, I have tried to change using material icon in the window, but steel is the default and cannot be changes.
      Thank you
    • Sahil Sura
      Hi @amansrivastav715,
      Once you double-click on the material name in the tree, the part with the assigned material gets highlighted. The same material gets reflected near the part with a drop-down menu, you can choose the material from the drop-down and the new material is assigned to the part.
      Hope that helps.
      Thanks,
      Sahil
