August 8, 2017 at 1:05 pm
jvswartz
SubscriberI want to be able to change the original sketch after I have entered 3D mode and generated a solid. I used to be able to do this is DesignModeler very easily, but cannot seem to find this in SpaceClaim.
September 4, 2017 at 7:41 pm
Holger Grotjans
Ansys EmployeeYou can use the Pull option and other functions to easily change the 3D geometry. Why would you need the sketch anymore?
December 11, 2018 at 3:26 pm
shkelzen
SubscriberIn inventor or solidwork, we return to scetch to edit the equation curve parameter.
I have 2 question.
Is it possible to draw a exponential function according to a given equation in DesignModeler (not through points);
If not, in a SpaceClaim we have option Equation (to create a geometry according to an equation). How to draw a 2d exponential function, and how to parameterize so we change depending for a certain value.
for example: I have to draw different sandwich symmetric exponential beam according to 20*E^((-1/200)*t), then another one (-0.75/200).
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
