How to change the position of axis of roation in joint load
    • Pravin0213
    • peteroznewman
    • PSiedlac123
      The location of rotation symbol is simply misleading.
      Please simply use right mouse button on Joint - Rotation and select Promote to Remote Point - You will create explicit handle to control point for Your torque. You can then control its position in detail.
