June 21, 2020 at 2:55 pm
junu
SubscriberWhen I start ANSYS FLUENT from either type of FLUENT-based system within Workbench, FLUENT Launcher will appear by default. Most FLUENT Launcher settings are available, except for the following option:
-Working Directory (disabled). So I can’t add the UDF file.
But with the fluent launcher (stand-alone) I can set my working directory. But from here I can’t switch to the post-CFD Result section. How do I do that??
June 22, 2020 at 12:35 pm
Ansys EmployeeWhen you're running stand alone save the case & data at the end of the run. Then launch CFD Post and read the files in. There are advantages and disadvantages to running in and outside of Workbench.
3648
2534
1745
1226
578
