November 16, 2020 at 2:06 am
b.x. Yang
SubscriberIn workbench, if I want to view my model in the direction of [1,-1,-1], how can I do that. In ansys, the command, /view, is capable to do it.nBest wishes!n -
November 16, 2020 at 2:49 pm
Dragana Jandric
Ansys EmployeeYou could use Views and/or Orient Options. Also you can use Manage ViewsFrom Help system,nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/wb_sim/ds_Ribbon_Display_tab.html%23ds_Ribbon_Display_tab_Orientn
- The topic ‘How to change view direction’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3151
1680
1470
