June 30, 2019 at 2:07 pm
Nishanth
SubscriberHello,
Please Check the attached images
So I need to check Lift, Drag, Lift-coefficient and Drag coefficient for the model which looks like the above-attached image.
I did name all the three sections as Slat_wall, wing_wall, and Flap_wall respectively and in reference values, I added the area of all the three walls.
Now to check the Lift across the Whole model In results I selected all the three walls (slat, wing, flap) and then checked the force in the Z direction for lift and X direction for Drag, Is it the correct method to calculate lift and drag across the whole model?
Also, Does co-efficient of pressure mean Co-efficient of lift when I'm checking in Z direction?
P.S: All the 3 walls are not attached.
July 1, 2019 at 5:03 am
DrAmine
Ansys EmployeeIt depend how the values you compare with or you refer to are gathered or measured. Your appriach sounds rational. Check reference values for coefficients calculation and check if the direction vectors for lift and drag are really perpendicular or parallel respectively to inflow direction. -
July 1, 2019 at 5:14 am
Nishanth
SubscriberIt depend how the values you compare with or you refer to are gathered or measured. Your appriach sounds rational. Check reference values for coefficients calculation and check if the direction vectors for lift and drag are really perpendicular or parallel respectively to inflow direction.
Hi abenhadj, Thank you for replying.
Yes, the lift and drag vectors are perpendicular and parallel, respectively.
By asking me to check reference values are you asking me to check areas and calulate co-efficients by lift and drag equations?
July 1, 2019 at 7:50 am
DrAmine
Ansys EmployeeYes. Best to get the reference values from inflow zone
July 1, 2019 at 9:37 am
July 1, 2019 at 11:11 am
DrAmine
Ansys EmployeePressure coefficients and drag coefficients. All these information is documented. Kind of dimensionsless groups made by calculating the ratio of the forces to dynamic pressure at inflow.
3694
2558
1763
1234
590
