how to choose the number of shells (shell conduction heat transfert fluent)
    • manelaero2020
      Hi everyone 👋
      I am simulating heat transfer by convection in a pipe. The thickness of the wall is 1 mm and I will use heat transfer shell conduction.
      My question is :
      may I consider one shell with a thickness of 1mm or divide this thickness into 2 or more shells?
      Do you think that the number of shells can affect heat transfer across the wall?
      Thank you for your assistance
    • Nikhil Narale
      Are you talking about number of layers? If you have multiple layers (of different material) in actual case, you can model that by adding layers. Else, a single layer will suffice.
    • manelaero2020
      Hi, @Nikhil Narale Thank you very much. Sorry for the late response. Yes, I'm talking about the number of layers.
      Should I mention to fluent the actual thickness of the material, please?
    • Nikhil Narale
      For only one material layer, you can define the actual thickness value. No need to add additional layers.
      • manelaero2020
        thank you a lot
Viewing 3 reply threads
