March 15, 2023 at 2:24 am
CHIEH TING WANG
Subscriber -
March 15, 2023 at 2:42 am
CHIEH TING WANG
SubscriberBy the way I used ansys fluent of result
March 15, 2023 at 11:26 am
Ansys EmployeeIf you create a face there in geometry and split the domain you'll get an interior zone: you can post process on that. Otherwise look at iso-surface in Fluent and combine that with iso-clip to trim to shape.
March 15, 2023 at 5:04 pm
CHIEH TING WANG
SubscriberThank you with your reply!
I try to use 'surface from edges' in DesignModeler to create surface but first problem i met this
and when i keep using this way until the set up it happened says'Unassigned interface zone detected for interface8'and could not initialize
Was it i do not split with Domain?if it was how could i split it?
March 16, 2023 at 10:19 am
Ansys EmployeeIf you're using Workbench Meshing you need a single multibody part coming from DM. Then check and (probably) delete all contacts in Meshing: there's a tolerance check which can cause false interface pairs.
You REALLY want to be using 2023R1 too. R17 is about 7-8 years old now and the technology has moved on a fair bit.
March 16, 2023 at 6:25 pm
CHIEH TING WANG
SubscriberHi! thank you with your reply !
the problem as you say to delete contact region solved the problem of 'Initialize',I am really appreciate!
but I met a new problem when I was using result I couldn't find the surface that i set how could be?
By the way I stilled used 'surface from edge ' to create the plane,should I suppose to create rigid body?
March 17, 2023 at 11:56 am
Ansys EmployeeIf you just created a surface and didn't split anything that surface won't pass to Fluent. You'll have to either remesh or use the iso-surfaces in Fluent.
- How can i get stress-strain data points for defining Multilinear isotropic hardening in Ansys
- Reynolds Number in Fully Developed Turbulent Flow
- Opening course files using ANSYS 19.1
- Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Error Object: #f
- Formula SAE Composite Monocoque Chassis Analysis – Geometry File
- Mesh fail
- Coriolis Flowmeter 2 way FSI workshop files
- Ansys innvoation course files
- Turbulent flow
- How to get the Ansys Course Completion: Intro to Python Badge
3694
2564
1765
1234
590
