April 20, 2023 at 1:32 am
Edward Suh
SubscriberHi,
I am simulating via model, and I would like know how to compuete differential via impedance each layer. We can use the exisiting example projejct \Examples\HFSS 3D Layout\Signal Integrity\Diff_Via.aedt. There are two signal vias(postive/negative) and 2 ground vias. We delete ground vias, and the design is simpler.
There are total 12 signal layers, and I like to know how to compuate each differential impedance of via pads.
Which port I have to use and how to setup? And, how to compuate each differential impedance after simulation?
Thanks!
- Maxwell, HFSS or Q3D?
- Error
5290
3311
2471
