May 4, 2022 at 9:53 am
lschuler
SubscriberHi,
I am performing an electrical analysis in Ansys Mechanical and I would like to compute the value of the electrical current going through a surface (which is the integral of the current density over the surface).
I only see the possibility to plot the current density but not the total current.
Thank you for your help.
May 4, 2022 at 10:27 amErik Kostson
Ansys EmployeeHi
There is no such output.
All the best
Erik
Viewing 1 reply thread- The topic ‘How to compute the electrical current through a surface in Ansys Mechanical?’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
