How to conduct solar radiation simulation in Ansys Fluent?
    • arpatil_31
      Hello Everyone,
      I am conducting solar radiation simulation for concrete road 0.2m thickness and concrete wall of 5 m height and 20 m length but getting un-realistic results. The details of the fluent boundary condition settings are as follows:
      Radiation Model- DO
      Solar Ray Tracing: Solar calculator- I have defined altitude, longitude, time zone, day, month, time, East-North mesh direction.
      Direct Solar Irradiation- 1040 w/m2, Diffuse Solar Irradiation- 95 w/m2, Spectral Fraction- 0.5
      Concrete material properties:
      Density: 2000 Kg/m3
      Sp. Heat: 960 J/kg.K
      Thermal Conductivity: 1.5 W/m.K
      Absorption Coefficient: 1.7 1/m
      Scattering Coefficient: 0 1/m
      Refractive Index: 0
      Air material properties:
      Density: ideal gas
      Sp. Heat: 1006.43 J/kg.K
      Thermal Conductivity: 0.0242 W/m.K
      Absorption Coefficient: 0 1/m
      Refractive Index: 0
      Concrete road and wall boundary conditions:
      Thermal condition- coupled, Emissivity- 0.9, Material- concrete
      Radiation BC type- Opaque, Diffuse fraction- 1, Solar BC- participate in solar ray tracing,
      Absorptivity: Direct Visible- 0.6 and Direct IR-0.6
      Inlet BC: 1m/s, 42C temp., default radiation tab settings
      Outlet BC: pressure outlet, default radiation tab settings
      Using this setting, I am getting wall temperature more than 90 Deg. C. Also, radiation temperature is high.
      Moreover, I kept different settings but still results are wrong.
      Kindly help me in solving the problem.
      Thanks in advance.
      I'd use incompressible ideal gas as it'll be more stable. I'd also review the refractive index of air: why did you set it as zero?n
    • arpatil_31
      Dear Rob,nThanks for reply. Mistakenly, I wrote 0 value for refractive index of air. I have used default 1 value. I kept density of air as in-compressible ideal gas but still temperature of concrete wall and road is near to 140 Deg. C. nMoreover, Wall boundary condition has created shadow walls and I have un-ticked the option of participate in solar ray tracing. Is it correct method or do I need to keep participate in solar ray tracing for shadow walls?nAfter Initialization, following message appears at text user interface:nInternally scattered energy: 1.75e+06 [w],nAmbient flux: 316 [w/m2]nTotal integral energy source: 4.2e+06 [w] {which is sum of integral energy of all boundary}nThough we used Direct Solar Irradiation- 1040 w/m2 and Diffuse Solar Irradiation- 95 w/m2. Why these values are very high?nThanks.n
    • arpatil_31
      Please help me in solving my problem.nThanksn
Viewing 3 reply threads
