January 16, 2023 at 3:36 am
ywang2524
SubscriberI want to use shell conduction on the wall between two fluid regions. How to connect two fluid regions in the meshing tool? I know I can form new a part in designmodeler but I do not want to generate conformal mesh in that way. Thanks for helping.
January 16, 2023 at 5:25 am
SRP
SubscriberHi,
You can modify or manipulate the mesh after it has been read into Ansys Fluent. For details please refer to user's guide: 6.12. Modifying the Mesh (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thank you
Saurabh
January 16, 2023 at 5:10 pm
ywang2524
SubscriberHi, thanks for your suggestion! What if the contact interfaces are not exactly the same, can they still be merged? I tried to merge the interfaces but failed.
January 16, 2023 at 5:47 am
Keyur Kanade
Ansys EmployeeI assume you have A.msh and B.msh for fluid regions. In Fluent you can append mesh files and create non conformal mesh.
If you want to have conformal mesh then you will need to use ICEMCFD to connect A and B. The recommended approach is form a single part in DM and use share topo and then mesh it to have conformal mesh.
Keyur
January 17, 2023 at 5:24 am
Keyur Kanade
Ansys EmployeeInterface should be topologically same. The mesh size also should be similar.
Please go through help manual for more details
Keyur
January 18, 2023 at 5:10 am
ywang2524
SubscriberThanks! If I can not merge the two interfaces into one wall, which means there will be two virtual walls, then the via coupled boudary condition and shell conduction are not applicable, then which kind of BC should I use and how will the heat transfered between this two walls?
2600
2088
1319
1108
459
