December 1, 2022 at 4:12 pm
December 1, 2022 at 5:48 pm
Akshay Maniyar
Ansys EmployeeHi javat33489,
Please try using blend option in SC.
Please check Ansys help link for more details.
Thanks,
Akshay Maniyar
December 1, 2022 at 6:17 pm
SubscriberYou can Pull the circular edge around the Axis to make a bend with a circular cross-section.
The Blend surface doesn't seem to maintain a circular cross-section at the 45 degree sweep angle.
December 1, 2022 at 7:22 pm
javat33489
Subscriber>>You can Pull the circular edge around the Axis to make a bend with a circular cross-section.
Can you elaborate please?
Yes, the cross section is narrow
December 2, 2022 at 3:08 pm
SubscriberI saw in your image an axis that is available. If that axis is not in the correct location create one that is.
With the Select tool active (keyboard S) select the circular edge.
Activate the Pull tool (keyboard P). An onscreen menu will popup. Click the Axis button then select the axis.
Drag the edge and see the bend surface revolve about the axis. Type in 90 in the popup angle field and hit enter to get a 90 degree bend surface.
December 2, 2022 at 6:46 pm
javat33489
SubscriberEverything works, thank you
2066
1279
1096
457
