3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
how to convert a faceted hollow body to a solid body?
    • pavelxmares
    • Subashni Ravichandran
      Forum Moderator
      Hello Pavel Mareš
      Are you using Discovery or SpaceClaim for this?
      In both, you can just right click on the Facet body and Convert to solid.
      Is there any error you are seeing?
      • pavelxmares
        Subashni
        SpaceClaim
        this is coming, but it is too big:
        To set STL file options
        Select STL in the panel on the left.
        Set Import options:
        Units: Choose a system of units.
        Import as:
        Connected faceted body: Create a lightweight mesh with full connectivity information between facets.
        Simple faceted body: Create a lightweight mesh with no connectivity information between facets.
        Solid/surface body: Convert STL triangles into full geometry.
        Check the Merge faces check box to seamlessly merge one or more faces.
        I have faceted body and I want to fill it out
      • pavelxmares
        Pavel Mareš
        ok, right click on the Facet body and Convert to solid.
        Thanks!
      Forum Moderator
      Pavel Mareš
      So did the Convert to solid option work? Is the issue resolved?
      • pavelxmares
        Subashni
        Yes, thanks!
  • The topic ‘how to convert a faceted hollow body to a solid body?’ is closed to new replies.
