September 21, 2022 at 2:35 pm
AMaity
SubscriberHello,
I was wondering if someone can lead me to get all these spectra wrt wavelengths. https://optics.ansys.com/hc/en-us/articles/360042160993######################################################
## Script: plasmon_mode_excitation_scattering_linear.lsf
## this script will plot the results from the parameter
## sweep.
## Variables:
## run_sim: 0, do not run any simulation (load results from file)
## 1, run simulations (parameter sweep)
## Copyright 2019 Lumerical Inc.
clear;
sweep_name = "sweep_polarization";
run_sim = 1; # 0, do not run any simulation
# 1, run sweep
if (run_sim) {
runsweep(sweep_name);
scat = getsweepresult(sweep_name, "scat");
total = getsweepresult(sweep_name, "total");
energy = scat.energy;
scat = scat.sigma;
total = -total.sigma;
ext = scat + total;
# Linear x
plot(energy, pinch(scat, 2, 1), pinch(total, 2, 1), pinch(ext, 2, 1),
"energy (eV)", "cross section (m^2)", "Linear x polarization");
setplot("x min", 2);
setplot("x max", 3.2);
legend("Scattering", "Absorption", "Extinction");
# Linear y
plot(energy, pinch(scat, 2, 2), pinch(total, 2, 2), pinch(ext, 2, 2),
"energy (eV)", "cross section (m^2)", "Linear y polarization");
September 21, 2022 at 5:27 pm
Guilin Sun
Ansys EmployeeYou want to know how to convert wavelength to energy? it is inside the analysis group:
sigma.addparameter("lambda",c/f,"f",f, "energy", h*f/e);
where e and h are reserved constants in Lumerical:
e is the charge;
h is the Plank constant.
energy=f*h/e=(c/lambda)*h/e
September 21, 2022 at 6:35 pm
AMaity
SubscriberHi Guilin,
Thanks for your prompt reply. So far I got the impression that if I make the following changes, it will work:plot(lambda, pinch(scat, 2, 1), pinch(total, 2, 1), pinch(ext, 2, 1),
"lambda(nm)", "cross section (m^2)", "Linear x polarization");
setplot("x min", 500);
setplot("x max", 650);
Let me know what you think.
Regards
Achyut
September 22, 2022 at 3:47 pm
Guilin Sun
Ansys EmployeeIt is roughly ok. What the unit you use for the wavelength? it seems in nanometer, which is ok.
This indicates they are in nanometers.
September 22, 2022 at 4:09 pm
AMaity
SubscriberThe following errors are coming up:
Error: C:/Users/3055376/Downloads/Plasmon mode excitation/plasmon_mode_excitation_linear.lsf line 32: lambda is not a valid function or variable name
Error: C:/Users/3055376/Downloads/Plasmon mode excitation/plasmon_mode_excitation_linear.lsf line 32: could not create a figure windowIt does not seem to be working
September 22, 2022 at 5:32 pm
Guilin Sun
Ansys EmployeePlease modify the analysis script in the group, as the origingal dataset does not have "lambda". Instead, it uses "energy". Please modify it.General description about dataset can be found here: https://optics.ansys.com/hc/en-us/articles/360034409554-Introduction-to-Lumerical-datasets
- Error on Lumerical device
2722
2146
1357
1150
462
