February 11, 2021 at 7:53 pm
obidahalawneh
SubscriberHello,
I have downloaded the THUMS model provided by Toyota recently, and the files are in Key file, and k file format, which I believe are supposed to open on LS-DYNA, but I don't have LS-Dyna and would like to open those files in ANSYS workbench, is that possible?
If yes how can it be done?
February 21, 2023 at 2:18 pmLuisa Hornung
SubscriberHave you managed to do this by now? I want to work also with LS-DYNA and the THUMS Model, but I cant find any instructions how to import the THUMS into LS-DYNA.
April 23, 2023 at 3:54 pm煜杰 葉
SubscriberHello, I am facing the same issue. Is there any solution available now?
April 24, 2023 at 5:23 amLuisa Hornung
SubscriberI have not found anything by now. I am working with the model in LS Dyna...
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5242
3299
2469
